Ana içeriğe geç
Squier Strat Guitar Pickups Replacement
Neye ihtiyacın var
  1. Squier Strat Guitar Pickups Replacement, Pickups: adım 1, 3 resimden 1. Squier Strat Guitar Pickups Replacement, Pickups: adım 1, 3 resimden 2. Squier Strat Guitar Pickups Replacement, Pickups: adım 1, 3 resimden 3.
    • Unwind the strings by turning the tuning pegs.
    • Pull the strings out of the tuning peg holes.
    • Push the strings out through the back plate holes.
    • Use a string winder to speed up this process.
  2. Squier Strat Guitar Pickups Replacement: adım 2, 2 resimden 1. Squier Strat Guitar Pickups Replacement: adım 2, 2 resimden 2.
    • Remove the 11 screws holding the pickguard to the body of the guitar.
  3. Squier Strat Guitar Pickups Replacement: adım 3, 3 resimden 1. Squier Strat Guitar Pickups Replacement: adım 3, 3 resimden 2. Squier Strat Guitar Pickups Replacement: adım 3, 3 resimden 3.
    • Lift up the pickup guard gently.
    • Flip the pickup guard to expose the wiring.
    • Place a towel underneath the pickup guard to protect your guitar's body.
    • Potential for device damage: Do not use excessive force when lifting the pickup guard.
  4. Squier Strat Guitar Pickups Replacement: adım 4, 2 resimden 1. Squier Strat Guitar Pickups Replacement: adım 4, 2 resimden 2.
    • Take note of where each pickup is wired.
    • Make sure to keep track of the negative and positive wires. Black wires usually indicate negative wires.
    • Pickups are usually wired to the potentiometers and pickup selector switch.
  5. Squier Strat Guitar Pickups Replacement: adım 5, 2 resimden 1. Squier Strat Guitar Pickups Replacement: adım 5, 2 resimden 2.
    • Desolder the pickups from the pickup selector switch using a quality soldering iron and soldering wick.
    • Desolder the pickups from the potentiometers.
    • Potential for device damage: Excessive heat from the soldering iron can damage components.
  6. Squier Strat Guitar Pickups Replacement: adım 6, 2 resimden 1. Squier Strat Guitar Pickups Replacement: adım 6, 2 resimden 2.
    • Flip the pickup guard back to its original position.
    • Remove the screws holding the pickups to the pickup guard.
  7. Squier Strat Guitar Pickups Replacement: adım 7, 2 resimden 1. Squier Strat Guitar Pickups Replacement: adım 7, 2 resimden 2.
    • Flip the pickup guard to reveal the wiring.
    • Remove the pickups from the pickup guard. They should come out very easily.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ion
479 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-5, Green Fall 2015 Cal Poly, Team 10-5, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 70
Her zaman: 6,849
