Ana içeriğe geç
Stanley ST-222A-120 Pressure Sensor Replacement
  1. Stanley ST-222A-120 Pressure Sensor Replacement, Pressure Sensor: adım 1, 1 resimden 1.
    • Unplug the heater for safety during your repair.
  2. Stanley ST-222A-120 Pressure Sensor Replacement: adım 2, 3 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 2, 3 resimden 2. Stanley ST-222A-120 Pressure Sensor Replacement: adım 2, 3 resimden 3.
    • With your hands gently remove the plastic covers on either side of the heater.
  3. Stanley ST-222A-120 Pressure Sensor Replacement: adım 3, 2 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 3, 2 resimden 2.
    • Use your hands to pry apart the plastic halves of the heater to see the internals of the device.
  4. Stanley ST-222A-120 Pressure Sensor Replacement: adım 4, 2 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 4, 2 resimden 2.
    • Locate small pressure sensor replacement and small pressure pin at the bottom of the device.
  5. Stanley ST-222A-120 Pressure Sensor Replacement: adım 5, 2 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 5, 2 resimden 2.
    • Use your hands to help guide the pressure pin back into a position where the replacement plate can slide back onto it.
    • Needle nose pliers may be a good assistant in this situation.
  6. Stanley ST-222A-120 Pressure Sensor Replacement: adım 6, 2 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 6, 2 resimden 2.
    • While the plastic is open hold the pin out with a finger.
    • Line up the pressure plate to the pressure pin.
  7. Stanley ST-222A-120 Pressure Sensor Replacement: adım 7, 2 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 7, 2 resimden 2.
    • Gently put the pressure plate back onto the pressure pin.
  8. Stanley ST-222A-120 Pressure Sensor Replacement: adım 8, 3 resimden 1. Stanley ST-222A-120 Pressure Sensor Replacement: adım 8, 3 resimden 2. Stanley ST-222A-120 Pressure Sensor Replacement: adım 8, 3 resimden 3.
    • Carefully press the plastic back together.
    • Be conscious not to interrupt the placement of the newly repaired pressure plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 516
