Ana içeriğe geç
Stapler Maintenance
    1. Stapler Maintenance, Open & Identify: adım 1, 2 resimden 1. Stapler Maintenance, Open & Identify: adım 1, 2 resimden 2.
      • Be careful while handling staples or any sharp object in general.
      • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
      • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
      FixBot'a Sor
      Yorum Ekle
    2. Stapler Maintenance, Insert Staples: adım 2, 2 resimden 1. Stapler Maintenance, Insert Staples: adım 2, 2 resimden 2.
      • Get a cluster of staples and carefully place it in the carrier.
      • Make sure there is enough room for the pusher to contact the staples.
      • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
      FixBot'a Sor
      Yorum Ekle
    3. Stapler Maintenance: adım 3, 1 resimden 1.
      • Don’t staple your hand, or anyone else for that matter.
      • Congratulations! You have successfully replaced staples in your stapler.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Sequoia Equities
279 İtibar
1 Kılavuz yazıldı
2Kılavuz Yorumları
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Yanıt Paylaş
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 60
Son 7 gün: 586
Son 30 gün: 2,741
Her zaman: 59,040
