Ana içeriğe geç
Stapler Spring Replacement
Neye ihtiyacın var
  1. Stapler Spring Replacement, Spring: adım 1, 2 resimden 1. Stapler Spring Replacement, Spring: adım 1, 2 resimden 2.
    • Open the stapler by gripping the handle to access the spring.
    FixBot'a Sor
    Yorum Ekle
  2. Stapler Spring Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Pry open the hook found on the pusher using the tweezers.
    • Hold the handle firmly to prevent the stapler from snapping back.
    FixBot'a Sor
    Yorum Ekle
  3. Stapler Spring Replacement: adım 3, 1 resimden 1.
    • Unhook the end of the spring from the pusher.
    • Pinch the spring firmly between your fingers to keep it from snapping back.
    FixBot'a Sor
    Yorum Ekle
  4. Stapler Spring Replacement: adım 4, 2 resimden 1. Stapler Spring Replacement: adım 4, 2 resimden 2.
    • Unhook the other end of the spring from the inside of the handle.
    • The spring should be unthreaded from the holes on the handle's metal part.
    FixBot'a Sor
    Yorum Ekle
  5. Stapler Spring Replacement: adım 5, 2 resimden 1. Stapler Spring Replacement: adım 5, 2 resimden 2.
    • Press down on the metal part inside the handle with your thumbs until it will not go down anymore.
    FixBot'a Sor
    Yorum Ekle
  6. Stapler Spring Replacement: adım 6, 2 resimden 1. Stapler Spring Replacement: adım 6, 2 resimden 2.
    • Push the hammer, the rectangular piece, up and away from the metal part.
    FixBot'a Sor
    Yorum Ekle
  7. Stapler Spring Replacement: adım 7, 1 resimden 1.
    • Release the metal part inside the handle so it comes away from the hammer.
    • Keep hold of the metal part to keep it from snapping closed.
    FixBot'a Sor
    Yorum Ekle
  8. Stapler Spring Replacement: adım 8, 1 resimden 1.
    • Hook one end of the new spring onto the pusher's hook.
    FixBot'a Sor
    Yorum Ekle
  9. Stapler Spring Replacement: adım 9, 1 resimden 1.
    • Clamp the pusher's hook closed using your thumb.
    FixBot'a Sor
    Yorum Ekle
  10. Stapler Spring Replacement: adım 10, 1 resimden 1.
    • Thread the other end of the new spring through the top rectangular hole toward the back.
    FixBot'a Sor
    Yorum Ekle
  11. Stapler Spring Replacement: adım 11, 1 resimden 1.
    • Thread the new spring through the bottom hole, bringing the end of spring toward you.
    • The spring should create a loop when done threading.
    FixBot'a Sor
    Yorum Ekle
  12. Stapler Spring Replacement: adım 12, 2 resimden 1. Stapler Spring Replacement: adım 12, 2 resimden 2.
    • Hook the new spring to the hook on the inside of the handle's metal part.
    FixBot'a Sor
    Yorum Ekle
  13. Stapler Spring Replacement: adım 13, 2 resimden 1. Stapler Spring Replacement: adım 13, 2 resimden 2.
    • Press the metal part down with your thumbs until it aligns with the hammer's hole.
    FixBot'a Sor
    Yorum Ekle
  14. Stapler Spring Replacement: adım 14, 2 resimden 1. Stapler Spring Replacement: adım 14, 2 resimden 2.
    • Reattach the hammer back onto the metal part.
    FixBot'a Sor
    Yorum Ekle
  15. Stapler Spring Replacement: adım 15, 2 resimden 1. Stapler Spring Replacement: adım 15, 2 resimden 2.
    • Close the handle until it clicks back into place.
    • Be careful not to staple your fingers when closing the stapler.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
14Kılavuz Yorumları
Just what I needed. Thank you! Super clear
Daniela Labra - Yanıt Paylaş
Can I replace the black rubber piece that goes on my swingling desk top stapler 70 sheet it came off and my dog chewed it up.
Edith Corkell - Yanıt Paylaş
fron this sale ski o donde venden los repuestos de esta engrapadora en Venezuela gran caracas
Romulo - Yanıt Paylaş
Where do I obtain a replacement spring for this stapler?
John Drake - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 144
Son 7 gün: 1,122
Son 30 gün: 5,139
Her zaman: 308,414
