Giriş
If your pencils are not properly sharpening, the problem could be a dull or worn cutter. This guide will show you how to replace the cutter component of your Staples 34462 Electric Pencil Sharpener.
Neye ihtiyacın var
Orient the top panel so that the sensor bracket is facing you.
Using a Phillips00 screwdriver, remove four 10.42mm screws.
Using a Phillips00 screwdriver, remove two 6.96mm screws.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
where can I get a replacement cutter?
