Ana içeriğe geç
Staples 34462 Electric Pencil Sharpener Power Cord Replacement
Neye ihtiyacın var
  1. Staples 34462 Electric Pencil Sharpener Power Cord Replacement, Cover: adım 1, 1 resimden 1.
    • Pull out the shavings tray from the pencil sharpener.
    • Beware of loose pencil shavings falling on your workspace.
  2. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 2, 1 resimden 1.
    • Turn the pencil sharpener on its side.
  3. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 3, 1 resimden 1.
    • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
    • Using the plastic opening tool, remove the back plastic feet.
    • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
    • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
  4. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 4, 1 resimden 1.
    • Carefully pull apart the bottom panel from the top panel.
    • Be careful not to pull too forcefully as the panels are connected by wires.
    • Beware of pencil shavings falling out onto your workspace.
  5. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 5, 1 resimden 1.
    • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
  6. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 6, 1 resimden 1.
    • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
  7. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 7, 1 resimden 1.
    • Carefully pull the cover from the top panel and set it aside.
  8. Staples 34462 Electric Pencil Sharpener Power Cord Replacement, Power Cord: adım 8, 1 resimden 1.
    • Orient the panel with the power cord so that it is facing you.
    • Using a Phillips00 screwdriver, remove the two flat head 8.95mm screws securing the cord.
  9. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 9, 1 resimden 1.
    • Using a Phillips00 screwdriver, remove the two 10.42mm screws on the plastic frame securing the power component.
  10. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 10, 1 resimden 1.
    • Carefully lift out the power component from the panel.
  11. Staples 34462 Electric Pencil Sharpener Power Cord Replacement: adım 11, 1 resimden 1.
    • Use a utility knife to cut the black insulation tape from the wire.
    • Cut the power cord from the wires to remove it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 559
