Ana içeriğe geç
Starbucks Barista Ready Light Replacement
Neye ihtiyacın var
  1. Starbucks Barista Ready Light Replacement, Ready Light: adım 1, 2 resimden 1. Starbucks Barista Ready Light Replacement, Ready Light: adım 1, 2 resimden 2.
    • Unscrew the 6 screws from the back panel.
    • Remove the back panel.
  2. Starbucks Barista Ready Light Replacement: adım 2, 3 resimden 1. Starbucks Barista Ready Light Replacement: adım 2, 3 resimden 2. Starbucks Barista Ready Light Replacement: adım 2, 3 resimden 3.
    • Locate the ready light.
    • Gently push the fixture against the Barista wall.
    • Pull the fixture straight up to release it.
    • Note: The fixture works as a spring.
    • Note: The green cover from the front panel will "pop" off. Do not lose the green cover.
    • Disconnect the wire lead connectors.
    • Remove the ready light unit (fixture).
  3. Starbucks Barista Ready Light Replacement: adım 3, 1 resimden 1.
    • Replace the old LED with a new LED.
    • To put back, match the green cover to the slot of the LED fixture, then slide the fixture down against the barista wall.
Sonuç
Bir başkası bu kılavuzu tamamladı.
David
739 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G42
4 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
Beee2smoove.
Rich Ridout - Yanıt
Youth and sports for
Rich Ridout - Yanıt
Ttuii addinsists
Rich Ridout - Yanıt
Where can I get a new LED bulb?
Paula - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 6,097
