Ana içeriğe geç
Starbucks Barista Steam Wand replacement or cleaning
Neye ihtiyacın var
  1. Starbucks Barista Steam Wand replacement or cleaning, steam wand: adım 1, 1 resimden 1.
    • Using a wrench, unscrew the hex nut and remove the steam wand.
    • Note: Do not lose the hex nut once it is unscrewed.
  2. Starbucks Barista Steam Wand replacement or cleaning: adım 2, 2 resimden 1. Starbucks Barista Steam Wand replacement or cleaning: adım 2, 2 resimden 2.
    • Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
    • Place the steam wand in a de-calcifying solution as directed by product.
    • Reconnect the steam wand.
    • See the links section of the device page to purchase a new steam wand.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
David
748 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-42, Regan Winter 2011 Cal Poly, Team 4-42, Regan Winter 2011 üyesi
CPSU-REGAN-W11S4G42
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
R Cly - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 15,882
