Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The steam wand is used to steam and froth milk as well as dispense hot water for Americanos or tea.
Neye ihtiyacın var
Using a wrench, unscrew the hex nut and remove the steam wand.
Note: Do not lose the hex nut once it is unscrewed.
Using a thin tool or item, such as a paper clip, poke around through the holes on both ends of the wand to remove any foreign material.
Place the steam wand in a de-calcifying solution as directed by product.
Reconnect the steam wand.
See the links section of the device page to purchase a new steam wand.
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
To replace steam-wand seals (in case of water leaking out from the center of the steam-wand): https://www.youtube.com/watch?v=fulyy9A9... , but note - for parts: https://philips.encompass.com/model/SAER... (worth going to amazon.de and entering the partnumbers into the search box: e.g. the o-rings for the needle-valve (996530013462)
