Ana içeriğe geç
Steam Deck OLED Battery Disconnection
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Steam Deck OLED Battery Disconnection, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 1. Steam Deck OLED Battery Disconnection, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 2. Steam Deck OLED Battery Disconnection, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 3.
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Battery Disconnection, Remove the back cover screws: adım 2, 2 resimden 1. Steam Deck OLED Battery Disconnection, Remove the back cover screws: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Battery Disconnection, Unclip a handle: adım 3, 3 resimden 1. Steam Deck OLED Battery Disconnection, Unclip a handle: adım 3, 3 resimden 2. Steam Deck OLED Battery Disconnection, Unclip a handle: adım 3, 3 resimden 3.
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Battery Disconnection, Unclip the top and bottom edges: adım 4, 3 resimden 1. Steam Deck OLED Battery Disconnection, Unclip the top and bottom edges: adım 4, 3 resimden 2. Steam Deck OLED Battery Disconnection, Unclip the top and bottom edges: adım 4, 3 resimden 3.
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Battery Disconnection, Remove the back cover: adım 5, 3 resimden 1. Steam Deck OLED Battery Disconnection, Remove the back cover: adım 5, 3 resimden 2. Steam Deck OLED Battery Disconnection, Remove the back cover: adım 5, 3 resimden 3.
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED Battery Disconnection, Disconnect the battery: adım 6, 3 resimden 1. Steam Deck OLED Battery Disconnection, Disconnect the battery: adım 6, 3 resimden 2. Steam Deck OLED Battery Disconnection, Disconnect the battery: adım 6, 3 resimden 3.
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
Sonuç
Clay Eickemeyer
81.013 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.332 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 9
Son 30 gün: 9
Her zaman: 49
