Ana içeriğe geç
SteelSeries Apex 3 TKL USB Port Replacement
Neye ihtiyacın var
  1. SteelSeries Apex 3 TKL USB Port Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove all back panel screws.
  2. SteelSeries Apex 3 TKL USB Port Replacement: adım 2, 2 resimden 1. SteelSeries Apex 3 TKL USB Port Replacement: adım 2, 2 resimden 2.
    • Use the iFixit opening pick to pry open the back panel by running it along the edges of the keyboard.
  3. SteelSeries Apex 3 TKL USB Port Replacement, USB Port: adım 3, 1 resimden 1.
    • Release the ribbon wire connections using the metal spudger which has a more rigid tip for undoing the clips.
  4. SteelSeries Apex 3 TKL USB Port Replacement: adım 4, 1 resimden 1.
    • Use a JIS #00 screwdriver to remove the USB port cover.
  5. SteelSeries Apex 3 TKL USB Port Replacement: adım 5, 1 resimden 1.
    • Flip the motherboard over and carefully use the spudger to push out the connecting wire.
Sonuç
Use your new USB port insert back into the motherboard. To reassemble your device, follow these instructions in reverse order.
Tyler Pepe
169 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Santin Spring 2024 UMass Dartmouth, Team 1-3, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 24
