Ana içeriğe geç
SteelSeries Apex 64145 USB Port Connector Replacement
Neye ihtiyacın var
  1. SteelSeries Apex 64145 USB Port Connector Replacement, Gel Membrane: adım 1, 1 resimden 1.
    • Unplug the keyboard from the computer.
  2. SteelSeries Apex 64145 USB Port Connector Replacement: adım 2, 1 resimden 1.
    • Unscrew the twenty black 4.5 mm Phillips #1 screws on the back of the keyboard.
  3. SteelSeries Apex 64145 USB Port Connector Replacement: adım 3, 1 resimden 1.
    • Pry open the back of the keyboard.
  4. SteelSeries Apex 64145 USB Port Connector Replacement: adım 4, 2 resimden 1. SteelSeries Apex 64145 USB Port Connector Replacement: adım 4, 2 resimden 2.
    • Remove the gel membrane.
  5. SteelSeries Apex 64145 USB Port Connector Replacement, LED: adım 5, 2 resimden 1. SteelSeries Apex 64145 USB Port Connector Replacement, LED: adım 5, 2 resimden 2.
    • Unscrew the two silver 4.0 mm Phillips #1 screws and the three black 6.5 mm Phillips #1 screws holding the silicone sheets.
  6. SteelSeries Apex 64145 USB Port Connector Replacement: adım 6, 1 resimden 1.
    • Flip the chip slightly in order to remove the sheets.
  7. SteelSeries Apex 64145 USB Port Connector Replacement: adım 7, 1 resimden 1.
    • Remove the sheets.
  8. SteelSeries Apex 64145 USB Port Connector Replacement: adım 8, 2 resimden 1. SteelSeries Apex 64145 USB Port Connector Replacement: adım 8, 2 resimden 2.
    • Unscrew the two silver 4.5 mm Phillips #1 screws and the seven 5.0 mm Phillips #1 screws that deter the plastic panel from removal.
  9. SteelSeries Apex 64145 USB Port Connector Replacement: adım 9, 1 resimden 1.
    • Remove the plastic panel and the white sheet.
  10. SteelSeries Apex 64145 USB Port Connector Replacement: adım 10, 3 resimden 1. SteelSeries Apex 64145 USB Port Connector Replacement: adım 10, 3 resimden 2. SteelSeries Apex 64145 USB Port Connector Replacement: adım 10, 3 resimden 3.
    • Unplug the wires connected to the LEDs.
  11. SteelSeries Apex 64145 USB Port Connector Replacement: adım 11, 2 resimden 1. SteelSeries Apex 64145 USB Port Connector Replacement: adım 11, 2 resimden 2.
    • Remove the LEDs.
  12. SteelSeries Apex 64145 USB Port Connector Replacement, USB Port Connector: adım 12, 1 resimden 1.
    • Unscrew the two 4.5 mm silver Phillips #1 screws that hold the USB port connector.
  13. SteelSeries Apex 64145 USB Port Connector Replacement: adım 13, 1 resimden 1.
    • Unplug the wires and remove the USB port connector.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zwe Phone Shein
559 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G1, Nance Spring 2017 USF Tampa, Team S1-G1, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G1
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
the 2 usb in the keyboard what amp are they running on.. 500mA ? I hope for 1500-2000 mA
And what standard are they ? USB3 ??
Simon Sundström - Yanıt
can the other part be replaced too. like the power board ?
i think i have a powerboard problem and if I can replace it that would be awesome, as I love my keyboard and im
very very attached to it. I was playing a video game, nothing too harsh , and the lights went out and poof it never came back. never had a problem with this keyboard until 2 and a 1/2 years later that it did this. Its in a non-smoking room and gaming studio always kept very clean.
I would love to fix it to bring it back to life.
Twsted - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 42
Her zaman: 3,004
