Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. SteelSeries Gaming Headset cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. SteelSeries Arctis 1 Wireless Headset Teardown, Basics: adım 1, 2 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown, Basics: adım 1, 2 resimden 2.
    • The Basics:
    • Microphone port
    • Power button and LED
    • Micro-USB port
    • AUX cord IN
    • Volume wheel
    • Microphone mute/unmute
  2. SteelSeries Arctis 1 Wireless Headset Teardown, Remove Ear Cushions: adım 2, 3 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown, Remove Ear Cushions: adım 2, 3 resimden 2. SteelSeries Arctis 1 Wireless Headset Teardown, Remove Ear Cushions: adım 2, 3 resimden 3.
    • Let's start on the right side
    • Take off the ear cushions.
  3. SteelSeries Arctis 1 Wireless Headset Teardown, Disassembly: adım 3, 1 resimden 1.
    • Remove this small plastic piece.
  4. SteelSeries Arctis 1 Wireless Headset Teardown: adım 4, 2 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown: adım 4, 2 resimden 2.
    • Remove the piece under the top of the headphone
    • It should look like this when you are done
  5. SteelSeries Arctis 1 Wireless Headset Teardown: adım 5, 2 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown: adım 5, 2 resimden 2.
    • Time for the fun part
    • Take out the three Phillips screws with a Phillips #000 screwdriver
  6. SteelSeries Arctis 1 Wireless Headset Teardown: adım 6, 2 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown: adım 6, 2 resimden 2.
    • CAREFULLY pull apart the two halves
    • There is still a wire connecting the two halves. Do not pull straight up.
  7. SteelSeries Arctis 1 Wireless Headset Teardown: adım 7, 3 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown: adım 7, 3 resimden 2. SteelSeries Arctis 1 Wireless Headset Teardown: adım 7, 3 resimden 3.
    • Let's get a closer look at these components.
    • Be careful to not damage the battery. If the battery is inflated or otherwise damaged, responsibly dispose of the battery.
    • Repeat steps 2-4 on the left side.
  8. SteelSeries Arctis 1 Wireless Headset Teardown: adım 9, 1 resimden 1.
    • Take out the three Torx Security screws with a size 6 screwdriver
  9. SteelSeries Arctis 1 Wireless Headset Teardown: adım 10, 2 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown: adım 10, 2 resimden 2.
    • Carefully separate the two sides
    • Again, there is a wire connecting both sides. Be careful to not break the connections.
    • The wires on the board are fragile. I accidentally pulled one off while reassembling the headset. I guess I have some soldering to do :(
  10. SteelSeries Arctis 1 Wireless Headset Teardown: adım 11, 3 resimden 1. SteelSeries Arctis 1 Wireless Headset Teardown: adım 11, 3 resimden 2. SteelSeries Arctis 1 Wireless Headset Teardown: adım 11, 3 resimden 3.
    • Again, let's get a closer look.
  11. SteelSeries Arctis 1 Wireless Headset Teardown, Conclusion: adım 12, 1 resimden 1.
    • Thank you for reading. As mentioned above, this is my first guide, so please feel free to make suggestions or list inaccuracies. Thank you!
BC279
205 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 58
Her zaman: 308
