Ana içeriğe geç
Steelseries Rival 3 Scroll Wheel Replacement
Neye ihtiyacın var
  1. Steelseries Rival 3 Scroll Wheel Replacement, Scroll Wheel: adım 1, 1 resimden 1.
    • Disconnect the mouse from your laptop/personal computer.
  2. Steelseries Rival 3 Scroll Wheel Replacement: adım 2, 2 resimden 1. Steelseries Rival 3 Scroll Wheel Replacement: adım 2, 2 resimden 2.
    • Remove the three mouse skates with a prying tool.
    • Your prying tool may slip when removing the skates so proceed with caution.
    • If new skates are needed, purchase them at SteelSeries Rival 3 Mouse Skates.
  3. Steelseries Rival 3 Scroll Wheel Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the four screws from the base of the mouse and remove the casing.
  4. Steelseries Rival 3 Scroll Wheel Replacement: adım 4, 1 resimden 1.
    • Remove the wire that is connected to the circuit board of the mouse as shown in the image.
    • The wire and the socket can be damaged if not handled with care.
  5. Steelseries Rival 3 Scroll Wheel Replacement: adım 5, 1 resimden 1.
    • Carefully take off the circuit board and lay it on the surface being used.
    • Be careful when doing so to prevent the wire connected to the base of the mouse from breaking.
  6. Steelseries Rival 3 Scroll Wheel Replacement: adım 6, 2 resimden 1. Steelseries Rival 3 Scroll Wheel Replacement: adım 6, 2 resimden 2.
    • Remove the four black screws along the circuit board using a Phillips #0 screwdriver.
  7. Steelseries Rival 3 Scroll Wheel Replacement: adım 7, 1 resimden 1.
    • Remove the scroll wheel by taking it out of its socket.
    • The socket is the silver tower that allows the mouse to turn while keeping the scroll wheel stiff.
  8. Steelseries Rival 3 Scroll Wheel Replacement: adım 8, 1 resimden 1.
    • Insert your new scroll wheel into the tower where the scroll wheel was originally.
    • Ensure not to apply excessive force during the process.
    • Before you put the mouse back together, make sure the scroll wheel turns smoothly in order for the mouse to work.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 29
Son 30 gün: 69
Her zaman: 137
