Ana içeriğe geç
Sterwins HC 150 bar cleaner pump replacement
  1. Sterwins HC 150 bar cleaner pump replacement, Removing the handle from the winder: adım 1, 2 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Removing the handle from the winder: adım 1, 2 resimden 2.
    • Before any intervention on the device, make sure that the power cord is disconnected.
    • Pull on the winder handle facing you to unclip it.
  2. Sterwins HC 150 bar cleaner pump replacement, Winder disassembly: adım 2, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Winder disassembly: adım 2, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Winder disassembly: adım 2, 3 resimden 3.
    • Unscrew the 2 housing fixing screws.
    • Remove the housing.
    • Using a flathead screwdriver, remove the clips holding the high pressure outlet connector from the pump to the hose reel.
  3. Sterwins HC 150 bar cleaner pump replacement, Extraction of the winder: adım 3, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Extraction of the winder: adım 3, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Extraction of the winder: adım 3, 3 resimden 3.
    • Pull the connection towards you.
    • Move the 2 roller bearings outwards.
    • Then remove the winder one side at a time.
  4. Sterwins HC 150 bar cleaner pump replacement, Unplug the detergent container: adım 4, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Unplug the detergent container: adım 4, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Unplug the detergent container: adım 4, 3 resimden 3.
    • Unhook the container by pulling towards you.
    • Uncouple the suction hose by pulling in the direction of the arrow.
  5. Sterwins HC 150 bar cleaner pump replacement, Disassembly of the front: adım 5, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Disassembly of the front: adım 5, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Disassembly of the front: adım 5, 3 resimden 3.
    • Unscrew the 6 fixing screws indicated by the arrows.
    • Tilt the product forwards to access the last 2 fixing screws located under the device marked with the arrows.
    • Then lay the device flat, and unscrew the plastic nut from the water inlet pipe.
  6. Sterwins HC 150 bar cleaner pump replacement, Uncouple the front: adım 6, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Uncouple the front: adım 6, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Uncouple the front: adım 6, 3 resimden 3.
    • Remove the faceplate upwards.
    • Return the device to an upright position on its wheels.
    • Unscrew the screw indicated by the arrow to separate the bearing from the winder in order to extract the pump outlet pipe.
  7. Sterwins HC 150 bar cleaner pump replacement, Uncoupling of the winder bearing: adım 7, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Uncoupling of the winder bearing: adım 7, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Uncoupling of the winder bearing: adım 7, 3 resimden 3.
    • Once the fixing screw removed, slide the bearing as indicated by the arrow.
    • Then pull upwards to extract the bearing from the pipe.
    • Then remove the front panel.
  8. Sterwins HC 150 bar cleaner pump replacement, Access to the On/Off switch: adım 8, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Access to the On/Off switch: adım 8, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Access to the On/Off switch: adım 8, 3 resimden 3.
    • Remove the button facing you.
    • Unscrew the 2 screws as indicated in order to separate the support.
    • Then unscrew the 6 screws and remove the hatch to access the electrical connection.
  9. Sterwins HC 150 bar cleaner pump replacement, Electrical disconnection: adım 9, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Electrical disconnection: adım 9, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Electrical disconnection: adım 9, 3 resimden 3.
    • Remove the switch from its housing.
    • Uncouple the red power cable from the On/Off switch.
  10. Sterwins HC 150 bar cleaner pump replacement, Uncoupling the pump: adım 10, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Uncoupling the pump: adım 10, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Uncoupling the pump: adım 10, 3 resimden 3.
    • Unscrew the 3 fixing screws of the pump using the allen key.
    • Turn the device over, unscrew the 2 screws of the pump retaining hoop.
    • Then pull it up.
  11. Sterwins HC 150 bar cleaner pump replacement, Extraction of the pump: adım 11, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Extraction of the pump: adım 11, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Extraction of the pump: adım 11, 3 resimden 3.
    • Lift the pump upwards.
    • Be careful to note the passage of the high pressure pipe, indicated by the yellow arrow.
    • Be careful to note the passage of the detergent pipe, indicated in green by the arrow and the circle.
  12. Sterwins HC 150 bar cleaner pump replacement, Pump replacement: adım 12, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Pump replacement: adım 12, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Pump replacement: adım 12, 3 resimden 3.
    • Fit the suction pipe of the detergent container.
    • Install the pump outlet pipe.
  13. Sterwins HC 150 bar cleaner pump replacement, Attach the pump motor: adım 13, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Attach the pump motor: adım 13, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Attach the pump motor: adım 13, 3 resimden 3.
    • Install the pump motor retaining arch.
    • Tighten the 2 arch fixing screws.
    • Turn the device over on the front face in order to reattach the 3 pump motor retaining screws.
  14. Sterwins HC 150 bar cleaner pump replacement, Positioning of the electrical cable: adım 14, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Positioning of the electrical cable: adım 14, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Positioning of the electrical cable: adım 14, 3 resimden 3.
    • Position the cable block on the housing as indicated by the red arrow.
    • Position the excess cable as indicated by the yellow arrow
  15. Sterwins HC 150 bar cleaner pump replacement, Connect the ON/OFF switch: adım 15, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Connect the ON/OFF switch: adım 15, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Connect the ON/OFF switch: adım 15, 3 resimden 3.
    • Connect the power cord (red) to the On/Off switch, taking care to match brown with brown (phase) and blue with blue (neutral).
    • Be careful not to forget to connect the grounding cable (yellow/green) as indicated by the yellow arrows.
    • Reposition the switch in its housing indicated by the orange arrows, as well as the cables indicated by the green arrows.
  16. Sterwins HC 150 bar cleaner pump replacement, Reassembly of the control plate: adım 16, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Reassembly of the control plate: adım 16, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Reassembly of the control plate: adım 16, 3 resimden 3.
    • Position the plate and tighten its 6 fixing screws.
    • Put the control lever back in place.
    • Insert the 2 fixing screws of the button support.
  17. Sterwins HC 150 bar cleaner pump replacement, Install the front panel: adım 17, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Install the front panel: adım 17, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Install the front panel: adım 17, 3 resimden 3.
    • Be careful before fitting the front panel, do not forget the control button by positioning its notch with the control lever (as shown in the photo).
    • Insert the hose into the channel of the bearing support of the reel.
  18. Sterwins HC 150 bar cleaner pump replacement, Fasten the reel bearing: adım 18, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Fasten the reel bearing: adım 18, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Fasten the reel bearing: adım 18, 3 resimden 3.
    • Insert the pipe into the bearing.
    • Insert the slide of the support into that of the front.
    • Put the fixing screw back in place.
  19. Sterwins HC 150 bar cleaner pump replacement, Attach the front: adım 19, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Attach the front: adım 19, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Attach the front: adım 19, 3 resimden 3.
    • Reposition the front panel, aligning the notches correctly.
    • Screw the plastic nut of the water inlet pipe back on.
    • Tighten the 8 front fixing screws.
  20. Sterwins HC 150 bar cleaner pump replacement, Put the winder back in place: adım 20, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Put the winder back in place: adım 20, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Put the winder back in place: adım 20, 3 resimden 3.
    • Connect the hose to the winder.
    • Install the locking clips.
    • Tighten the 2 casing fixing screws
  21. Sterwins HC 150 bar cleaner pump replacement, Replace the detergent container and handle: adım 21, 3 resimden 1. Sterwins HC 150 bar cleaner pump replacement, Replace the detergent container and handle: adım 21, 3 resimden 2. Sterwins HC 150 bar cleaner pump replacement, Replace the detergent container and handle: adım 21, 3 resimden 3.
    • Connect the suction hose to the detergent container.
    • Replace the container.
    • Insert the handle into the winder until it snaps into place.
  22. Sterwins HC 150 bar cleaner pump replacement, Necessary tools: adım 22, 1 resimden 1.
    • 1 clamp
    • 1 flat screwdriver
    • 1 Phillips screwdriver
    • 1 allen key size 6
Sonuç
By the end of the guide your pump should be replaced and fully functional.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
iRobot
1 İtibar
636 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 103
Her zaman: 2,733
