Ana içeriğe geç
Stihl O25 Chain Replacement
Neye ihtiyacın var
  1. Stihl O25 Chain Replacement, Stihl O25 Chain: adım 1, 1 resimden 1.
    • Be sure to turn off the chainsaw before servicing it.
    • Caution: Chainsaw blades are sharp. Wear protective gloves through the procedure.
    • Loosen the nuts on the chain cover with the wrench side of the scrench until the cover comes off of the saw.
  2. Stihl O25 Chain Replacement: adım 2, 1 resimden 1.
    • Pull the chain and chainsaw bar off of the power head.
    • Pull the chain back to loosen off of the gears, and lift straight up.
  3. Stihl O25 Chain Replacement: adım 3, 1 resimden 1.
    • Clean out the grooves on the chainsaw bar. This will help with the next step.
  4. Stihl O25 Chain Replacement: adım 4, 1 resimden 1.
    • Make sure the chain is positioned correctly. If you are looking at the top of the saw, the chain rotates away from the operator.
    • Position the chain so the teeth face away on the top of the saw.
  5. Stihl O25 Chain Replacement: adım 5, 1 resimden 1.
    • Place the bar and chain back onto the saw.
    • The bolt slot on the bar will slide onto the bolts on the saw.
    • The chain will go around the gear towards the back of the saw.
    • You may have to move the chain around to get it to fit properly.
  6. Stihl O25 Chain Replacement: adım 6, 2 resimden 1. Stihl O25 Chain Replacement: adım 6, 2 resimden 2.
    • Tighten the chain by turning the tightening screw.
    • Insert the screwdriver end of the scrench into the screw and turn clockwise.
  7. Stihl O25 Chain Replacement: adım 7, 1 resimden 1.
    • Chain tightness is often a preference of the chainsaw operator, but a good rule of thumb to follow is when you pull up on the chain, two chain links should come out of the bar grooves.
  8. Stihl O25 Chain Replacement: adım 8, 1 resimden 1.
    • Put the cover back on and tighten the nuts down.
  9. Stihl O25 Chain Replacement: adım 9, 1 resimden 1.
    • To sharpen the chain, mark one of the teeth with a pencil or sharpie.
  10. Stihl O25 Chain Replacement: adım 10, 1 resimden 1.
    • Take a round file and place it on the cutting surface.
  11. Stihl O25 Chain Replacement: adım 11, 1 resimden 1.
    • The file should be angled slighty upwards and follow the angle of the saw tooth.
    • Slide the file while applying pressure and twist slightly.
    • Teeth on a saw alternate which way they are facing.
    • Skip one tooth to continue to sharpen on the same side. Use the same number of file strokes on each tooth.
    • Continue to sharpen until you reach the original tooth that was marked. You can then sharpen the set of teeth facing the other way with the same process.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Nathan Comar
182 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 59
Her zaman: 1,711
