Ana içeriğe geç
Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement
  1. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Top Floater Removal: adım 1, 1 resimden 1.
    • Remove the black screw by rotating it counterclockwise.
  2. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 2, 1 resimden 1.
    • Hold the device in place and pull up on the floater.
  3. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the top floater.
  4. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Battery: adım 4, 1 resimden 1.
    • Turn the device upside-down.
  5. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 5, 1 resimden 1.
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
  6. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 6, 1 resimden 1.
    • A push tab holds the battery in.
  7. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 7, 1 resimden 1.
    • Push the tab in and pull the battery outward to remove it.
  8. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Lower Panel: adım 8, 1 resimden 1.
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
  9. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 9, 1 resimden 1.
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
  10. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement, Activation Buttons: adım 10, 1 resimden 1.
    • There are two action buttons on each side of the main body.
  11. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 11, 1 resimden 1.
    • Push on the top outer corner of each action button to pop them out of place.
  12. Sublue WhiteShark Mix Underwater Scooter Activation Buttons Replacement: adım 12, 1 resimden 1.
    • After each action button is released, pull outward to remove.
Sonuç
Benjamin J Farland
271 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 47
