Ana içeriğe geç
Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement
  1. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Top Floater Removal: adım 1, 1 resimden 1.
    • Remove the black screw by rotating it counterclockwise.
  2. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: adım 2, 1 resimden 1.
    • Hold the device in place and pull up on the floater.
  3. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: adım 3, 1 resimden 1.
    • Remove the top floater.
  4. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Battery: adım 4, 1 resimden 1.
    • Turn the device upside-down.
  5. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: adım 5, 1 resimden 1.
    • Press the push button in while sliding the planner towards the back of the device to remove the battery panel.
  6. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: adım 6, 1 resimden 1.
    • A push tab holds the battery in.
  7. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: adım 7, 1 resimden 1.
    • Push the tab in and pull the battery outward to remove it.
  8. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Lower Panel: adım 8, 1 resimden 1.
    • Remove the ten Phillips screws on the bottom of the device. Remove the bottom panel.
  9. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement: adım 9, 1 resimden 1.
    • Pull the panel forward.
    • You may need to use pry tools to aid in separating the panels.
  10. Sublue WhiteShark Mix Underwater Scooter Safety Switch Replacement, Safety Switch: adım 10, 1 resimden 1.
    • Place the main body panel with the handle that holds the safety switch towards you. Pull the white tab of the right and pull towards you from the top of the safety switch.
Sonuç
Benjamin J Farland
271 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-6, Gulbrandsen Fall 2023 üyesi
UMASSD-GULBRANDSEN-F23S2G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 35
