Giriş
I realized — a little too late — that a couple of retaining clips were rubbing against the top of the subwoofer/enclosure in my car. One clip was (thankfully) scratching the subwoofer enclosure carpet, but the other one had poked a hole on the subwoofer's rubber surround.
I removed the retaining clips so there would be no issues in the future, but the damage had already been done. So I figured what the heck — might as well make a guide!
Neye ihtiyacın var
Assess the damage. Depending on the severity of the cut, you may need some other scaffolding material (aside from RTV silicone) to enclose the hole.
In this case, all we need to do is cover up the tear with RTV silicone in order to make the subwoofer almost as good as new — functionally, at least.
Use a flat pry tool (such as a flat-blade screwdriver) to prop up an edge of the subwoofer.
Slide your fingers underneath the sub so that you get a good grip on its edge.
Carefully lift the subwoofer out of the enclosure, minding any wires that may be tethering the sub to the enclosure.
Cut the end off a cotton swab in order to transform it into an RTV applicator.
Dip the swab into the RTV silicone, and use it to apply the RTV silicone to the underside of the subwoofer tear.
You do not need a huge amount of RTV silicone on either side of the rubber surround — just enough to form a very thin layer.
After you're done applying the RTV silicone and testing the subwoofer's excursion, shine a strong flashlight through the now-covered hole, and ensure that no light bleeds through.
Ensure the sub wires are still connected properly, and reinstall the subwoofer back into the enclosure.
24 farklı kişi bu kılavuzu tamamladı.
18 Yorum
I have repaired many using fingernail polish. It may take several applications depending on the size but it forms a strong durable bond. Also works great on the cone.
Just be careful what silicone you use. Some may degrade the cone and other parts of the subwoofer.
