Ana içeriğe geç
Summer 3D Lite Convenience Stroller Back Wheel Replacement
  1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: adım 1, 2 resimden 1. Summer 3D Lite Convenience Stroller Back Wheel Replacement, Back Wheel: adım 1, 2 resimden 2.
    • Set the stroller up so the front wheel is on the ground with the metal push tab up.
  2. Summer 3D Lite Convenience Stroller Back Wheel Replacement: adım 2, 2 resimden 1. Summer 3D Lite Convenience Stroller Back Wheel Replacement: adım 2, 2 resimden 2.
    • Push the tab in with your finger enough so the plastic can slip out above the tab.
  3. Summer 3D Lite Convenience Stroller Back Wheel Replacement: adım 3, 1 resimden 1.
    • OPTIONAL: If the tab is being difficult, use a key to push the tab in further in order to slip plastic out of place.
  4. Summer 3D Lite Convenience Stroller Back Wheel Replacement: adım 4, 1 resimden 1.
    • The wheel should slide right off the pole once the tab is pushed out of place. It is now possible to make repairs or replace the wheel completely.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nick Taylor
188 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 11-5, Forte Fall 2015 Cal Poly, Team 11-5, Forte Fall 2015 üyesi
CPSU-FORTE-F15S11G5
4 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Gd, have a question . Were can u buy spare parts for this type of stroller?
pieterroos - Yanıt
Can you tell me if you have a rear wheel that will fit a summer 3D go convenience stroller all black?
charles nelms - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 85
Her zaman: 10,904
