Ana içeriğe geç
Summer LookOut Duo Camera Lens Replacement
Neye ihtiyacın var
  1. Summer LookOut Duo Camera Lens Replacement, Camera Lens: adım 1, 2 resimden 1. Summer LookOut Duo Camera Lens Replacement, Camera Lens: adım 1, 2 resimden 2.
    • Remove the plastic wall mount attached to the base of the stand.
    • Remove the four 9 mm screws on the back four corners of the camera using a Phillips #00 screwdriver.
    • If needed, gently bend the antenna of the camera towards you to access the screw in the bottom left corner.
  2. Summer LookOut Duo Camera Lens Replacement: adım 2, 3 resimden 1. Summer LookOut Duo Camera Lens Replacement: adım 2, 3 resimden 2. Summer LookOut Duo Camera Lens Replacement: adım 2, 3 resimden 3.
    • Gently remove the front casing.
    • The motherboard will go with the front casing, so don't pull too hard or else the wires connected to the speaker might break.
    • The back of the motherboard should already be facing up.
    • Remove the two 5 mm screws near the upper center on the back of the motherboard using a Phillips #00 screwdriver.
    • The old camera lens will fall off after the screws are removed.
    • Replace the new lens.
Sonuç
Jordyn Looney
425 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 89
