Ana içeriğe geç
Sun King Solo Solar Lantern Battery Replacement
Neye ihtiyacın var
  1. Sun King Solo Solar Lantern Battery Replacement, Locate and Remove the Screws: adım 1, 1 resimden 1.
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Battery Replacement, Separate the Device: adım 2, 1 resimden 1.
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: adım 3, 2 resimden 1. Sun King Solo Solar Lantern Battery Replacement, Isolate the Battery: adım 3, 2 resimden 2.
    • Locate the battery.
    • Gently lift the battery from the device.
  4. Sun King Solo Solar Lantern Battery Replacement, Remove the Battery: adım 4, 1 resimden 1.
    • Locate the clip attaching the battery pack to the circuit board.
    • Use tweezers to remove the portion of the clip attached to the battery.
    • Do not pull directly on the wires! They can easily be damaged.
  5. Sun King Solo Solar Lantern Battery Replacement, Replace the Battery: adım 5, 1 resimden 1.
    • Align the black wire of the new battery towards the center of the device.
    • Press down firmly on the clip to insure that it is properly connected.
    • Properly dispose of the Lithium-Ion Battery. Lithium Battery Disposal
  6. Sun King Solo Solar Lantern Battery Replacement, Reseat the Battery: adım 6, 1 resimden 1.
    • Seat the battery in the orange component so that the short end of the battery pack is touching the foam bumper.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Anna
595 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
8 Yorum
please help in finding the life p04 battery,3.2v ,1500 mah,batch #20309
SHARATH PONUGOTI - Yanıt
as my solar lights battery is dead..iam unable to find out whr i will get a new one
where to get the battery spare part?
johnkoisasi - Yanıt
Please help me in finding PRO sunking battery 6.6v,1450mAh, Batch 30130.
Please contact me:stanleymayor944@yahoo.com
Stanley - Yanıt
Howi can get 6.6 v sunking pro battery?please help me.
kapildeo mandal - Yanıt
I want to buy a battery for sunking pro lantern. How i can get it? Please help me.
I want to buy a battery for sunking pro lantern. Where can I can get it? Please help me.
tigroulu@gmail.com
Carlier Lucie - Yanıt
Where to get sun king pro solar battery?
Ramesh Kumar P - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 4,130
