Ana içeriğe geç
Sun King Solo Solar Lantern Device Seals Replacement
Neye ihtiyacın var
  1. Sun King Solo Solar Lantern Device Seals Replacement, Locate and Remove the Screws: adım 1, 1 resimden 1.
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Device Seals Replacement, Separate the Device: adım 2, 1 resimden 1.
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Device Seals Replacement, O-ring Replacement: adım 3, 2 resimden 1. Sun King Solo Solar Lantern Device Seals Replacement, O-ring Replacement: adım 3, 2 resimden 2.
    • On the clear upper half, remove the black O-ring
    • Place the new O-ring, making sure it is smooth all the way around
  4. Sun King Solo Solar Lantern Device Seals Replacement, Stand Holder Replacements: adım 4, 1 resimden 1.
    • Remove the rubber stand holders.
    • Place the new stand holders, making sure the wings of the holder are in the second opening
Sonuç
Josef Simek
120 İtibar
1 Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 465
