Ana içeriğe geç
Sun King Solo Solar Lantern Hand Strap Replacement
Neye ihtiyacın var
  1. Sun King Solo Solar Lantern Hand Strap Replacement, Locate and Remove the Screws: adım 1, 1 resimden 1.
    • Place the lamp LED side down on a clean workspace.
    • Remove the screws holding the casing together using a Phillips #1 Screwdriver.
  2. Sun King Solo Solar Lantern Hand Strap Replacement, Separate the Device: adım 2, 1 resimden 1.
    • Gently pull the two halves of the lamp apart.
  3. Sun King Solo Solar Lantern Hand Strap Replacement, Remove Strap: adım 3, 1 resimden 1.
    • Remove both ends of the strap from the orange casing by pulling up.
  4. Sun King Solo Solar Lantern Hand Strap Replacement, Replace the Strap: adım 4, 1 resimden 1.
    • Insert the ends of the new strap into the strap housing on both sides of the orange component.
    • Either strap housing (inner or outer) can be used to adjust the strap length.
Sonuç
Anna
595 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Fall 2014 Michigan Tech, Team 1-3, Lauer Fall 2014 üyesi
MTU-LAUER-F14S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 303
