Giriş
When the life or strength of your battery starts to diminish, you may want to look into a battery replacement. Here is all steps needed to change the battery in your Sungale CyberUs.
Neye ihtiyacın var
Hold the device so the left side is facing towards you (like in the picture shown) so the two 4mm PH001 screws are exposed and easier to access.
Now, carefully we will remove the battery. Find the leads, or the red and black wires going to the battery from the motherboard. To free the wires you must cut the wire near the battery leads. Make sure both ends are clean and have enough exposed wire.
