Ana içeriğe geç
Sungale Cyberus ID707WTA Speaker Replacement
Neye ihtiyacın var
  1. Sungale Cyberus ID707WTA Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Press firmly on lower portion of the back cover and slide the cover towards the bottom to remove cover.
  2. Sungale Cyberus ID707WTA Speaker Replacement: adım 2, 1 resimden 1.
    • Pull on the plug carefully until it releases from the port and simply pull the battery out after.
  3. Sungale Cyberus ID707WTA Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Pry open the casing with a plastic opening tool .
  4. Sungale Cyberus ID707WTA Speaker Replacement: adım 4, 2 resimden 1. Sungale Cyberus ID707WTA Speaker Replacement: adım 4, 2 resimden 2.
    • Unscrew the five 4.5 mm screws to allow access to the motherboard.
    • Lift the motherboard and set it onto the backside of the screen.
  5. Sungale Cyberus ID707WTA Speaker Replacement: adım 5, 1 resimden 1.
    • Pry the speaker out of retainer clip with iFixit pry tool.
  6. Sungale Cyberus ID707WTA Speaker Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Pry the speaker clip from the motherboard using tweezers.
Sonuç
Austin_Parkes
337 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S4-G4, Baechle Spring 2018 IUPUI, Team S4-G4, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S4G4
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 114
