Ana içeriğe geç
Super Nintendo Cartridge Battery Replacement
Neye ihtiyacın var
  1. Super Nintendo Cartridge Battery Replacement, Battery: adım 1, 3 resimden 1. Super Nintendo Cartridge Battery Replacement, Battery: adım 1, 3 resimden 2. Super Nintendo Cartridge Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the two 3.8mm security screws from the front panel of the game cartridge using a 3.8mm Gamebit screwdriver to reveal the circuit board.
    • It's good to have a white mat or bright sheet on your work surface to be able to see any small items like screws more easily and protect the surface from damage like hot solder dripping down.
  2. Super Nintendo Cartridge Battery Replacement: adım 2, 3 resimden 1. Super Nintendo Cartridge Battery Replacement: adım 2, 3 resimden 2. Super Nintendo Cartridge Battery Replacement: adım 2, 3 resimden 3.
    • Mount the circuit board on to the adjustable circuit board holder.
    • Desolder the two soldering points on the back of the circuit board holding the battery in place to remove the battery.
    • Use a soldering rest or holder to avoid damage to the surface when you need to put the soldering iron down.
  3. Super Nintendo Cartridge Battery Replacement: adım 3, 2 resimden 1. Super Nintendo Cartridge Battery Replacement: adım 3, 2 resimden 2.
    • Use the soldering iron and the de-soldering braid to remove any excess soldering adhesive.
    • Excess solder needs to be removed so that the new battery can be mounted properly.
  4. Super Nintendo Cartridge Battery Replacement: adım 4, 2 resimden 1. Super Nintendo Cartridge Battery Replacement: adım 4, 2 resimden 2.
    • Use the soldering iron with the soldering wire on the two soldering points to adhere the new battery to the circuit board.
  5. Super Nintendo Cartridge Battery Replacement: adım 5, 2 resimden 1. Super Nintendo Cartridge Battery Replacement: adım 5, 2 resimden 2.
    • Place the circuit board back into the cartridge and screw the front panel back in place with the 3.8mm security screws using a 3.8mm Gamebit screwdriver.
    • Optional: It would be advisable to clean the finished circuit board before mounting it back into the cartridge.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Mohamad Mohamad
436 İtibar
3 adet Kılavuz yazıldı
Ekip
York University, Team M-6, Allen Summer 2023 York University, Team M-6, Allen Summer 2023 üyesi
YORK-ALLEN-SU23SMG6
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 44
Son 30 gün: 180
Her zaman: 1,317
