Ana içeriğe geç
Super Nintendo Controller Port Replacement
Neye ihtiyacın var
  1. Super Nintendo Controller Port Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    FixBot'a Sor
  2. Super Nintendo Controller Port Replacement: adım 2, 3 resimden 1. Super Nintendo Controller Port Replacement: adım 2, 3 resimden 2. Super Nintendo Controller Port Replacement: adım 2, 3 resimden 3.
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    FixBot'a Sor
  3. Super Nintendo Controller Port Replacement, Eject Button: adım 3, 2 resimden 1. Super Nintendo Controller Port Replacement, Eject Button: adım 3, 2 resimden 2.
    • Lift the right side of the eject lever out of the housing.
    FixBot'a Sor
  4. Super Nintendo Controller Port Replacement: adım 4, 3 resimden 1. Super Nintendo Controller Port Replacement: adım 4, 3 resimden 2. Super Nintendo Controller Port Replacement: adım 4, 3 resimden 3.
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
    FixBot'a Sor
  5. Super Nintendo Controller Port Replacement, Controller Port: adım 5, 1 resimden 1.
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
    FixBot'a Sor
  6. Super Nintendo Controller Port Replacement: adım 6, 2 resimden 1. Super Nintendo Controller Port Replacement: adım 6, 2 resimden 2.
    • Carefully remove the ribbon cable from its port.
    FixBot'a Sor
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
James Shirley
1.033 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G47
4 Üyeler
25 adet Kılavuz yazıldı
3Kılavuz Yorumları
I did a complete teardown of my 26 year old super Nintendo because I had to fix the AV jack. the hardest part was the de soldering. however upon putting it back together I could get the games to play, however it was in black and white…or even a grayish hue…and the controllers didn't work. shortly after the ribbon connecting the controller input to the system snapped on one end. do you think this was the issue, and where do I find a new one? Thanks.
Keith Goetting - Yanıt Paylaş
This isn’t complete. How about taking the face plate off?
Daniel Powers - Yanıt Paylaş
Find don’t look like screws they look like rivets
Steve Pitcher - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 45
Son 30 gün: 220
Her zaman: 36,877
