Ana içeriğe geç
Super Nintendo Eject Button Replacement
Neye ihtiyacın var
  1. Super Nintendo Eject Button Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Super Nintendo Eject Button Replacement: adım 2, 3 resimden 1. Super Nintendo Eject Button Replacement: adım 2, 3 resimden 2. Super Nintendo Eject Button Replacement: adım 2, 3 resimden 3.
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    FixBot'a Sor
    Yorum Ekle
  3. Super Nintendo Eject Button Replacement, Eject Button: adım 3, 2 resimden 1. Super Nintendo Eject Button Replacement, Eject Button: adım 3, 2 resimden 2.
    • Lift the right side of the eject lever out of the housing.
    FixBot'a Sor
    Yorum Ekle
  4. Super Nintendo Eject Button Replacement: adım 4, 3 resimden 1. Super Nintendo Eject Button Replacement: adım 4, 3 resimden 2. Super Nintendo Eject Button Replacement: adım 4, 3 resimden 3.
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow the instructions in reverse order.
12 farklı kişi bu kılavuzu tamamladı.
James Shirley
1.033 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G47
4 Üyeler
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 31
Son 30 gün: 150
Her zaman: 21,952
