Ana içeriğe geç
Super Nintendo Motherboard Replacement
Neye ihtiyacın var
  1. Super Nintendo Motherboard Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
  2. Super Nintendo Motherboard Replacement: adım 2, 3 resimden 1. Super Nintendo Motherboard Replacement: adım 2, 3 resimden 2. Super Nintendo Motherboard Replacement: adım 2, 3 resimden 3.
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
  3. Super Nintendo Motherboard Replacement, Power Switch: adım 3, 1 resimden 1.
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
  4. Super Nintendo Motherboard Replacement: adım 4, 2 resimden 1. Super Nintendo Motherboard Replacement: adım 4, 2 resimden 2.
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
  5. Super Nintendo Motherboard Replacement, Eject Button: adım 5, 2 resimden 1. Super Nintendo Motherboard Replacement, Eject Button: adım 5, 2 resimden 2.
    • Lift the right side of the eject lever out of the housing.
  6. Super Nintendo Motherboard Replacement: adım 6, 3 resimden 1. Super Nintendo Motherboard Replacement: adım 6, 3 resimden 2. Super Nintendo Motherboard Replacement: adım 6, 3 resimden 3.
    • Pull the metal bar out through the right side of the eject lever.
    • Make sure to keep track of the spring located on the left side of the lever as it may shoot off when removing the metal bar.
    • When reassembling, the procedure becomes more difficult due to the spring (marked red). We recommend that one person hold the spring in place (picture 3) while another person slides the metal bar back into the left housing, and slide the eject lever onto the metal bar.
  7. Super Nintendo Motherboard Replacement, Controller Port: adım 7, 1 resimden 1.
    • Lift the controller ports out of the housing, this should be done without much force. Take note of the location of the ribbon cable connection.
  8. Super Nintendo Motherboard Replacement: adım 8, 2 resimden 1. Super Nintendo Motherboard Replacement: adım 8, 2 resimden 2.
    • Carefully remove the ribbon cable from its port.
  9. Super Nintendo Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove the two Phillips two 11.6mm screws that connect the front shield to the motherboard.
  10. Super Nintendo Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift the front shield straight up to remove it from the motherboard.
  11. Super Nintendo Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the two silver 15.6 mm Phillips #2 screws on either side of the 62 pin connector.
  12. Super Nintendo Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the 11.8 mm Phillips #2 screw near the rear of the SNES.
  13. Super Nintendo Motherboard Replacement: adım 13, 1 resimden 1.
    • Lift the motherboard straight up to remove it.
Sonuç
45 farklı kişi bu kılavuzu tamamladı.
Melina
977 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G47
4 Üyeler
25 adet Kılavuz yazıldı
4Kılavuz Yorumları
There are several versions of the Super Nintendo. Steps for my version are a bit different.
joshenders - Yanıt
This seems to be a newer super nintendo. If you have one of the older ones, there will be a bit more screws but still basically the same steps.
Anonymous Idea -
There are two versions of the Super Nintendo- the one pictured here, and one with a sound chip board behind the game cartridge reader. These two models have different shells that are not interchangeable (important to know if you're looking to buy a replacement housing for your SNES)
Gena FM -
It’s possible they may be referring to the European/Japanese version of the Super Nintendo/Super Famicom. Either that, or it’s one of the weird, misshapen “reskins”.
Rupin Soland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 78
Son 30 gün: 429
Her zaman: 79,722
