Ana içeriğe geç
Super Nintendo Power Switch Replacement
Neye ihtiyacın var
  1. Super Nintendo Power Switch Replacement, Outer Case: adım 1, 1 resimden 1.
    • Remove the six screws located on the underside of the system using the Gamebit 4.5mm screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Super Nintendo Power Switch Replacement: adım 2, 3 resimden 1. Super Nintendo Power Switch Replacement: adım 2, 3 resimden 2. Super Nintendo Power Switch Replacement: adım 2, 3 resimden 3.
    • Carefully flip the unit back over.
    • Locate the seam. Lift and separate the upper half of the case from the lower half of the case.
    FixBot'a Sor
    Yorum Ekle
  3. Super Nintendo Power Switch Replacement, Power Switch: adım 3, 1 resimden 1.
    • Remove the two 11.7 mm Phillips #2 screws connecting the power switch to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Super Nintendo Power Switch Replacement: adım 4, 2 resimden 1. Super Nintendo Power Switch Replacement: adım 4, 2 resimden 2.
    • The power switch is connected to the motherboard near the top left of the console.
    • Carefully pull the connector from its socket on the motherboard. You may need to wiggle it out as you pull.
    • Do not detach the connector by pulling on the wires. This could damage the wires or the socket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Cameron Deines
718 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-47, Amido Fall 2010 Cal Poly, Team 4-47, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G47
4 Üyeler
25 adet Kılavuz yazıldı
2Kılavuz Yorumları
Any tips on how to tell if it's the power switch that needs replacing vs something else?
TopShopGames - Yanıt Paylaş
Look at it for any signs of physical damage, if you don't see any noticeable issues that you can fix then you can try cutting the two wires stripping off the ends of them, and very carefully touching the wires together while its plugged in. BE EXTREMELY CAREFUL WHILE DOING THIS DO NOT TOUCH THE EXPOSED WIRE. If you notice it turn on, immediately stop touching the wires together and unplug the console. This means that the switch itself is broken. If it doesn't turn on, stop touching the wire together and unplug the console. This means that it's likely a power cable issue.
Anders Hoff - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 29
Son 30 gün: 140
Her zaman: 26,624
