1. Open up the back on the tablet.
    • Open up the back on the tablet.
  2. Locate the camera.
    • Locate the camera.
    • Unscrew the two screws.
    • Use the J0 Phillps screw driver to unscrew the the two small screws on either side of the black peice.
    • Pull the black camera cover off and locate the camera with two gold bands running off upwards and to the right.
    • Follow the gold band the runs up towards the white and grey box connected to the green plate.
    • Use the wedge from step one to lift the grey box up.
    • The grey piece should open up towards you.
    • Now turn your attention back the camera.
    • Next, Follow the second gold band to right to the white paper, or the front camra.
    • Now, carefully remove the front camera with the same wedge from step one, six, and eight.
    • Use the same wedge used in step one and step six to go under the camera and carefully pry away from the sivler plating.
    • When the camera becomes loose, gental pull up and out to the right to silde the gold band out of the white and grey box.
Sonuç
Logan Robinson
493 İtibar
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 31
Her zaman: 33
