Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Once the tire is deflated, press the beading inside until it is removed from the rim.
Slide the plastic wedge tool under the beading of the tire, and pull it outwards.
Once the tire is removed from the rim on one side, do the same to other side.
Pull out the tire tube from the tire and transfer it into the new tire.
Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
Do the same to both sides of the beading. You will need to use the plastic tool for the other side.
Bir başkası bu kılavuzu tamamladı.
