Ana içeriğe geç
Supersonic Matrix SC-91MID Back Cover Replacement
Neye ihtiyacın var
  1. Supersonic Matrix SC-91MID Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • To begin, insert the plastic opening tool between the display and back cover and apply force until the back cover comes free from the device.
    FixBot'a Sor
    Yorum Ekle
  2. Supersonic Matrix SC-91MID Back Cover Replacement: adım 2, 3 resimden 1. Supersonic Matrix SC-91MID Back Cover Replacement: adım 2, 3 resimden 2. Supersonic Matrix SC-91MID Back Cover Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Carefully remove orange ribbons from the motherboard by opening the small plastic flaps and pulling with tweezers.
    • This will disconnect the front part of the tablet from the back entirely. Set it safely aside and continue
    FixBot'a Sor
    Yorum Ekle
  3. Supersonic Matrix SC-91MID Back Cover Replacement: adım 3, 2 resimden 1. Supersonic Matrix SC-91MID Back Cover Replacement: adım 3, 2 resimden 2.
    • To remove the battery, use the plastic opening tool to pry one corner off of the battery and gently move the opening tool down to pull up one side of the battery.
    • The battery is glued down, so some force may be required to remove it from the back cover.
    FixBot'a Sor
    Yorum Ekle
  4. Supersonic Matrix SC-91MID Back Cover Replacement: adım 4, 2 resimden 1. Supersonic Matrix SC-91MID Back Cover Replacement: adım 4, 2 resimden 2.
    • To remove the speakers, use the plastic opening tool to gently pry the speaker from the back cover, then use the tweezers to remove them fully.
    FixBot'a Sor
    Yorum Ekle
  5. Supersonic Matrix SC-91MID Back Cover Replacement: adım 5, 3 resimden 1. Supersonic Matrix SC-91MID Back Cover Replacement: adım 5, 3 resimden 2. Supersonic Matrix SC-91MID Back Cover Replacement: adım 5, 3 resimden 3.
    • To remove the motherboard, start by unscrewing the three (3) small Phillips head screws using a 1.5 mm Phillips head (Phillips #000) screwdriver.
    • The small red washers must be kept along with the screws when reassembling the device, make sure you store them safely until reassembling.
    • The motherboard has soldered connections to the battery, speakers, and the charging indicator LED. Be careful when pulling the motherboard from the back cover because these parts will come along with it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Turner
121 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 üyesi
IUPUI-WILSON-S18S1G1
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 456
