Ana içeriğe geç
Supersonic Matrix SC-91MID Motherboard Replacement
Neye ihtiyacın var
  1. Supersonic Matrix SC-91MID Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use the plastic opening tool to separate the screen from the back cover.
  2. Supersonic Matrix SC-91MID Motherboard Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to lift the tab shown in the picture, and remove the orange ribbon from it gently. Repeat for all three ribbons on the device.
  3. Supersonic Matrix SC-91MID Motherboard Replacement: adım 3, 2 resimden 1. Supersonic Matrix SC-91MID Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the Phillips 1.5 mm screwdriver (Phillips #000) to unscrew the green motherboard from the body at the three points
    • Remove the washers (red)
  4. Supersonic Matrix SC-91MID Motherboard Replacement: adım 4, 2 resimden 1. Supersonic Matrix SC-91MID Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a hot soldering tool to desolder the wires connecting the motherboard to the speaker. Desolder the wires connecting the motherboard to the battery.
    • Red: Speakers
    • Orange: Battery
    • Yellow: LED
    • Check if your replacement motherboard comes with an LED. You may have to desolder the LED from your old motherboard and solder it to your replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sakshi Labhane
139 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 üyesi
IUPUI-WILSON-S18S1G1
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 51
Her zaman: 362
