Ana içeriğe geç
Supersonic Matrix SC-91MID Screen Replacement
Neye ihtiyacın var
  1. Supersonic Matrix SC-91MID Screen Replacement, Screen: adım 1, 2 resimden 1. Supersonic Matrix SC-91MID Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Place the plastic opening tool between the screen and the main component and pry open between the two. Once removed place the main component in a safe place and continue working on the screen section.
    • Be aware of the ribbon cables when removing the display screen from the main component.
    FixBot'a Sor
    Yorum Ekle
  2. Supersonic Matrix SC-91MID Screen Replacement: adım 2, 3 resimden 1. Supersonic Matrix SC-91MID Screen Replacement: adım 2, 3 resimden 2. Supersonic Matrix SC-91MID Screen Replacement: adım 2, 3 resimden 3.
    • Place the plastic opening tool between the metal screen plate and the black front casing.
    • There are small clips where the plastic opening tool can be placed to help pry the screen from the casing.
    FixBot'a Sor
    Yorum Ekle
  3. Supersonic Matrix SC-91MID Screen Replacement: adım 3, 3 resimden 1. Supersonic Matrix SC-91MID Screen Replacement: adım 3, 3 resimden 2. Supersonic Matrix SC-91MID Screen Replacement: adım 3, 3 resimden 3.
    • Continue to slide the opening tool along the length of the casing until there is a clear separation between the screen and the cover (as shown in the third image).
    FixBot'a Sor
    Yorum Ekle
  4. Supersonic Matrix SC-91MID Screen Replacement: adım 4, 1 resimden 1.
    • Once there is a clearing, carefully remove the screen from the black cover. You now have separated the screen from the tablet device and and are now ready to replace screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Norikuni Nishikawa
139 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Spring 2018 IUPUI, Team S1-G1, Wilson Spring 2018 üyesi
IUPUI-WILSON-S18S1G1
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 35
Her zaman: 591
