Giriş
This guide demonstrates how to access the Supersonic Matrix SC-91MID tablet speakers, as well as how to remove and replace them. Replacing the tablet's speakers may be necessary due to water damage or a failed wire connection.
Before proceeding with this guide, make sure that the tablet is competely shut down. Also refer to this guide How To Solder and Desolder Connections to learn how to solder and desolder connections.
Caution:
When soldering and desoldering, wear the appropriate safety gear such as goggles and long sleeves, as solder can "spit" due to heat build up.
DO NOT TOUCH THE SOLDERING IRON!
If the soldering iron is too hot, you could damage the connectors and the device.
First, separate the back cover of the tablet by wedging the pryer tool into the crease between the back cover and touchscreen.
Bir başkası bu kılavuzu tamamladı.
