Ana içeriğe geç
Supersonic SC-777BT Camera Replacement
Neye ihtiyacın var
  1. Supersonic SC-777BT Camera Replacement, Camera: adım 1, 3 resimden 1. Supersonic SC-777BT Camera Replacement, Camera: adım 1, 3 resimden 2. Supersonic SC-777BT Camera Replacement, Camera: adım 1, 3 resimden 3.
    • Remove the back cover using the plastic opening tool.
    • Open the cover like a book so you do not disconnect the yellow plastic holding the cover to the motherboard.
  2. Supersonic SC-777BT Camera Replacement: adım 2, 3 resimden 1. Supersonic SC-777BT Camera Replacement: adım 2, 3 resimden 2. Supersonic SC-777BT Camera Replacement: adım 2, 3 resimden 3.
    • Remove the two screws using the screwdriver.
    • Use the tweezers to pull the camera out of place.
    • Be gentle while pulling it out so you do not pull any extra components out.
  3. Supersonic SC-777BT Camera Replacement: adım 3, 1 resimden 1.
    • Disconnect the yellow ribbon cable from the connector.
  4. Supersonic SC-777BT Camera Replacement: adım 4, 2 resimden 1. Supersonic SC-777BT Camera Replacement: adım 4, 2 resimden 2.
    • Remove camera.
    • It should just peel off like a sticker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 128
