Ana içeriğe geç
Giriş
If applications, device accessories or buttons are not responsive, your motherboard needs to be replaced.
  1. Pry open backing of the tablet using an iFixit opening tool. Pry open backing of the tablet using an iFixit opening tool.
    • Pry open backing of the tablet using an iFixit opening tool.
  2. Use a PH000 screwdriver to unscrew all four motherboard screws. Use a PH000 screwdriver to unscrew all four motherboard screws.
    • Use a PH000 screwdriver to unscrew all four motherboard screws.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Unscrew the holder of the camera and gently remove using tweezers. Remove the sensors using tweezers. Remove the sensors using tweezers.
    • Unscrew the holder of the camera and gently remove using tweezers.
    • Remove the sensors using tweezers.
  5. Detach the battery. Battery is attached with adhesive; no tools needed to remove. Using tweezers, lift and release the ribbon cable that was covered by the battery.
    • Detach the battery.
    • Battery is attached with adhesive; no tools needed to remove.
    • Using tweezers, lift and release the ribbon cable that was covered by the battery.
  6. Carefully remove the motherboard with your hands. Carefully remove the motherboard with your hands.
    • Carefully remove the motherboard with your hands.
Sonuç
Maiya Webster
344 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 4
Her zaman: 82
