Ana içeriğe geç
Surface Laptop Studio SSD Replacement
Neye ihtiyacın var
  1. Surface Laptop Studio SSD Replacement, Lower Case: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: adım 2, 2 resimden 1. Surface Laptop Studio SSD Replacement: adım 2, 2 resimden 2.
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: adım 3, 1 resimden 1.
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: adım 4, 1 resimden 1.
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: adım 5, 2 resimden 1. Surface Laptop Studio SSD Replacement: adım 5, 2 resimden 2.
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: adım 6, 2 resimden 1. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: adım 6, 2 resimden 2.
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: adım 7, 1 resimden 1.
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: adım 8, 1 resimden 1.
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: adım 9, 1 resimden 1.
    • Slide the SSD directly out of its socket.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Nate Ball
741 İtibar
5 adet Kılavuz yazıldı
5Kılavuz Yorumları
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Yanıt
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Yanıt
Can you fit a full sized ssd or only the short ones?
Omega_o7 - Yanıt
You can fit a full-size (M.2 2280) SSD in the Suface Laptop Studio, but you won't be reusing the metal bracket that is there for the small SDD (2230 size). More info available here: https://dancharblog.wordpress.com/2021/1...
DoktorDread -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 82
Son 30 gün: 338
Her zaman: 12,827
