Ana içeriğe geç
Giriş
Does your surfboard have a broken or loose fin? This guide will help you replace your surfboard fin to get you back on the water in no time!
Aletler
Parçalar
  1. Lay your surfboard down on a flat, durable surface long enough to support the length of your board. Lay your surfboard down on a flat, durable surface long enough to support the length of your board. Lay your surfboard down on a flat, durable surface long enough to support the length of your board.
    • Lay your surfboard down on a flat, durable surface long enough to support the length of your board.
  2. Make sure the small screw hole in front of the fin is free of debris and sand. Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside. Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside.
    • Make sure the small screw hole in front of the fin is free of debris and sand.
    • Insert the key into the hole and begin turning counter-clockwise to loosen the screw inside.
  3. Continue turning counter-clockwise until the screw is free. Continue turning counter-clockwise until the screw is free.
    • Continue turning counter-clockwise until the screw is free.
  4. Firmly grasp the fin with one hand and place your other hand on the surfboard for stabilization. Simultaneously lift the fin while tilting it backwards to remove the fin. Simultaneously lift the fin while tilting it backwards to remove the fin.
    • Firmly grasp the fin with one hand and place your other hand on the surfboard for stabilization.
    • Simultaneously lift the fin while tilting it backwards to remove the fin.
  5. Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle. Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle.
    • Notice the circular inlet on the rear bottom side of the fin. This inlet of the fin fits snuggly into the little rod located in the back of the fin slit on the board, much like a puzzle.
  6. With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit. Once you feel the back secure, bring the front of the fin down into the slit. Once you feel the back secure, bring the front of the fin down into the slit.
    • With your new or repaired fin, insert the back in first so that you feel the inlet on the fin clip into the little rod in the slit.
    • Once you feel the back secure, bring the front of the fin down into the slit.
  7. Place the screw back into the hole and begin turning clockwise using the key. Continue turning until the screw is tight and won't turn any more. Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
    • Place the screw back into the hole and begin turning clockwise using the key.
    • Continue turning until the screw is tight and won't turn any more.
    • Once the screw stops turning, do not continue to tighten or you may damage the screw or fin.
  8. Make sure the screw can no longer be seen.
    • Make sure the screw can no longer be seen.
    • Wiggle your fin gently to test for looseness, and you have successfully replaced your surfboard fin.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Hudson Albert
165 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 3,355
