Ana içeriğe geç
Suzuki FA50 Moped Exhaust Pipe Replacement
  1. Suzuki FA50 Moped Exhaust Pipe Replacement, Exhaust Pipe: adım 1, 1 resimden 1.
    • Use a #2 Phillips screwdriver to remove the heat shield from the muffler.
  2. Suzuki FA50 Moped Exhaust Pipe Replacement: adım 2, 1 resimden 1.
    • There are two 10 mm hex nuts attaching the muffler to the engine. Make sure you remove both of them before proceeding to the next step.
    • Use a 10 mm socket wrench to unscrew the two hex nuts.
  3. Suzuki FA50 Moped Exhaust Pipe Replacement: adım 3, 1 resimden 1.
    • Use a 12 mm socket wrench to unscrew the third and final hex nut that holds the muffler in place.
    • Make sure to support the muffler with your hand while removing this nut, otherwise it may just fall to the floor.
Sonuç
Bir başkası bu kılavuzu tamamladı.
One Comment
Thanks you very much! Happy Fourth of July.
D4Tay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 6,703
