Giriş
This guide can be used to replace the front brakes on your Suzuki FA50. All you need is a new set of brake shoes, basic tools, a bit of patience, and a bit of time.
WARNING: Drum brakes may contain asbestos, a silicate mineral that causes cancer and other nasty diseases. Make sure to use brake cleaner on the brake parts once you open the drum; this will minimize any asbestos entering your lungs. As an added precaution, you should also consider using a respirator during that portion of the repair.
Use your fingers to unscrew and remove the brake cable adjustment nut.
Remove the brake cable by pulling it straight out of the dust cover and its retaining bracket.
The black rubber boot (and spring within it) is now loose, so remove it from the brake line and set it aside until reassembly.
Place a 12 mm combination (or box-end) wrench over the lug nut on the opposite side of the front wheel.
While holding the lug nut with the combination wrench, use a 12 mm socket wrench to loosen the axle screw on the brake side of the wheel.
Slide the axle screw out and remove the front wheel from the moped.
Thoroughly spray the inside of the brake drum with a brake cleaning solvent.
Once the solvent has had a chance to work its magic (10 minutes or so), use a rough-grit sandpaper (100 grit or so) to clean the inner diameter of the drum. Rinse and repeat until you are satisfied with the cleanliness of the drum.
Carefully spread apart the round side of the brake shoes and place them through the round bolt on the brake drum assembly.
Then, spread apart the flat side of the brake shoes and place them through the flat bolt on the brake drum assembly.
The shoes should now be sitting as shown in the second and third pictures.
Insert the black rubber boot back on the brake cable.
Place the brake cable back in its retaining bracket and slide the rubber over the exposed braided cable.
At this point, you'll need to adjust the front brake arm because the new shoes are much thicker than the old ones (see next step).
First use the 8 mm socket wrench to tighten the brake arm retaining screw, so that the brake arm is in its held sturdily in its new position.
Then, tighten the brake cable adjusting nut with your fingers until your front brake lever is about 0.8 - 1.0" from the handlebar when fully engaged.
3 farklı kişi bu kılavuzu tamamladı.
