Ana içeriğe geç
SwagTron T1 Back Panels Replacement
Neye ihtiyacın var
  1. SwagTron T1 Back Panels Replacement, Back Panels: adım 1, 1 resimden 1.
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: adım 2, 3 resimden 1. SwagTron T1 Back Panels Replacement: adım 2, 3 resimden 2. SwagTron T1 Back Panels Replacement: adım 2, 3 resimden 3.
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: adım 3, 3 resimden 1. SwagTron T1 Back Panels Replacement: adım 3, 3 resimden 2. SwagTron T1 Back Panels Replacement: adım 3, 3 resimden 3.
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
Sonuç
Adrian Abarca
360 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 664
