Ana içeriğe geç
SwagTron T1 Gyroscope Replacement
Neye ihtiyacın var
  1. SwagTron T1 Gyroscope Replacement, Back Panels: adım 1, 1 resimden 1.
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Gyroscope Replacement: adım 2, 3 resimden 1. SwagTron T1 Gyroscope Replacement: adım 2, 3 resimden 2. SwagTron T1 Gyroscope Replacement: adım 2, 3 resimden 3.
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Gyroscope Replacement: adım 3, 3 resimden 1. SwagTron T1 Gyroscope Replacement: adım 3, 3 resimden 2. SwagTron T1 Gyroscope Replacement: adım 3, 3 resimden 3.
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Gyroscope Replacement, Gyroscope: adım 4, 2 resimden 1. SwagTron T1 Gyroscope Replacement, Gyroscope: adım 4, 2 resimden 2.
    • Disconnect the gyroscope by disconnecting the wires attached to it. These wires are black, green, blue and red.
  5. SwagTron T1 Gyroscope Replacement: adım 5, 1 resimden 1.
    • Using your Phillips #2 screwdriver, remove the four 8mm screws marked in red from the gyroscope.
  6. SwagTron T1 Gyroscope Replacement: adım 6, 3 resimden 1. SwagTron T1 Gyroscope Replacement: adım 6, 3 resimden 2. SwagTron T1 Gyroscope Replacement: adım 6, 3 resimden 3.
    • Carefully remove the gyroscope component from the SwagTron.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Teagan Allen
426 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G5
4 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
I cannot find a Swagtron T1 replacement gyroscope anywhere on the internet. Any help would be extremely appreciated!! Thank you!
Gavin Hosler - Yanıt
Amazon.com Keyword: CertiCable
Jesse Griffis -
Where do you get the replacement?
Brittany Conner - Yanıt
Can’t find gyroscope for a t5 hover board please help.
jbswearingen70739 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 70
Her zaman: 7,006
