Ana içeriğe geç
SwagTron T1 Wheel Replacement
Neye ihtiyacın var
  1. SwagTron T1 Wheel Replacement, Back Panels: adım 1, 1 resimden 1.
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Wheel Replacement: adım 2, 3 resimden 1. SwagTron T1 Wheel Replacement: adım 2, 3 resimden 2. SwagTron T1 Wheel Replacement: adım 2, 3 resimden 3.
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Wheel Replacement: adım 3, 3 resimden 1. SwagTron T1 Wheel Replacement: adım 3, 3 resimden 2. SwagTron T1 Wheel Replacement: adım 3, 3 resimden 3.
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
  4. SwagTron T1 Wheel Replacement, Wheel: adım 4, 3 resimden 1. SwagTron T1 Wheel Replacement, Wheel: adım 4, 3 resimden 2. SwagTron T1 Wheel Replacement, Wheel: adım 4, 3 resimden 3.
    • Using your Phillips #2 screwdriver, remove the four 1cm screws that attach the gyroscope and its black case to the hoverboard.
    • Carefully remove this component and set it off to the side.
  5. SwagTron T1 Wheel Replacement: adım 5, 3 resimden 1. SwagTron T1 Wheel Replacement: adım 5, 3 resimden 2. SwagTron T1 Wheel Replacement: adım 5, 3 resimden 3.
    • Using your H 6.0 allen wrench, remove the four 20mm black bolts shown in the picture.
    • Take off the iron plate holding the wheel in place.
    • Remove the Motor/Wheel and set it aside close by to the hoverboard.
    • The wires from the Motor/Wheel should still be connected to the motherboard.
    • These bolts are very tight, it may be difficult to remove them. Try using a tool with a long handle.
  6. SwagTron T1 Wheel Replacement: adım 6, 3 resimden 1. SwagTron T1 Wheel Replacement: adım 6, 3 resimden 2. SwagTron T1 Wheel Replacement: adım 6, 3 resimden 3.
    • Slide the protective plastic off the connectors on the marked wires (green, blue, and yellow) using your hands or a set of tweezers.
    • The connectors on the wires of your hoverboard may be different from those shown in the pictures on the left due to differences in manufacturing.
    • Separate the set of marked green, blue, and yellow wires from their connectors.
  7. SwagTron T1 Wheel Replacement: adım 7, 3 resimden 1. SwagTron T1 Wheel Replacement: adım 7, 3 resimden 2. SwagTron T1 Wheel Replacement: adım 7, 3 resimden 3.
    • Finally separate the last connector shown on the left.
    • Your wheel is completely removed; slide in a new Motor/Wheel into the slot and follow the previous steps in reverse order.
    • Make sure the replacement wheel is snug. Neither rubbing on the outer rim nor on the side of the hoverboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Teagan Allen
426 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G5, Banghart Spring 2017 Cal Poly, Team S17-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S17G5
4 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Where do you get replacement wheels?
Elizabeth Schumacher - Yanıt
Where can we find replacement wheels?
Liz Vance - Yanıt
Mine won't stop beeping?? Fully charged.
Rachael Anderson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 5,463
