Ana içeriğe geç
Swagtron T3 Battery Replacement
  1. Swagtron T3 Battery Replacement, Cover: adım 1, 2 resimden 1. Swagtron T3 Battery Replacement, Cover: adım 1, 2 resimden 2.
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Battery Replacement: adım 2, 3 resimden 1. Swagtron T3 Battery Replacement: adım 2, 3 resimden 2. Swagtron T3 Battery Replacement: adım 2, 3 resimden 3.
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
  3. Swagtron T3 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Unscrew the four 9.4 mm Phillips #1 machine screws attaching the battery to the base of the Swagtron T3.
  4. Swagtron T3 Battery Replacement: adım 4, 2 resimden 1. Swagtron T3 Battery Replacement: adım 4, 2 resimden 2.
    • Detach the two cables connecting the battery to the Swagtron by pinching the connector clips and pulling the cables apart:
    • One red and black cable with a yellow connector.
    • One blue cable with a black connector.
  5. Swagtron T3 Battery Replacement: adım 5, 2 resimden 1. Swagtron T3 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery by pulling it out from under the cables.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Neeki Jarrami
197 İtibar
1 Kılavuz yazıldı
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G3
4 Üyeler
4 adet Kılavuz yazıldı
10 Comments
where can i get a replacement battery?
rob - Yanıt
Where can I get a replacement battery?
rob - Yanıt
I can’t find a battery with the two wire harnesses coming out of the pack. Where can I order one?
Jeff Johnson - Yanıt
Where Can I purchase a replacement batter for the T3
Leandre - June 18
Leandre Thornton - Yanıt
Swagtron doesn’t sell the silver battery (even if you email them) I bought one from HoverboardRepair.com and it worked. Only difference is the small wire doesn’t come on the new battery but my hoverboard has worked just fine and I replaced the battery months ago.
Daniel Moravec - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 41
Her zaman: 7,111
