Ana içeriğe geç
Swagtron T3 Gyroscope Replacement
Neye ihtiyacın var
  1. Swagtron T3 Gyroscope Replacement, Cover: adım 1, 2 resimden 1. Swagtron T3 Gyroscope Replacement, Cover: adım 1, 2 resimden 2.
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Swagtron T3 Gyroscope Replacement: adım 2, 3 resimden 1. Swagtron T3 Gyroscope Replacement: adım 2, 3 resimden 2. Swagtron T3 Gyroscope Replacement: adım 2, 3 resimden 3.
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
    FixBot'a Sor
    Yorum Ekle
  3. Swagtron T3 Gyroscope Replacement, Gyroscope: adım 3, 1 resimden 1.
    • The gyroscope is a blue rectangular circuit board on top of a white base and is closest to the wheel.
    • Detach the four cables connecting the gyroscope to the hoverboard by pinching the connector clips and pulling the cables out:
    • Three red and black cables with white connectors.
    • One multicolored cable with a black connector.
    FixBot'a Sor
    Yorum Ekle
  4. Swagtron T3 Gyroscope Replacement: adım 4, 1 resimden 1.
    • Uncrew the four 7.2 mm Phillips #1 self-drilling screws connecting the blue gyroscope to the white plastic holding piece.
    FixBot'a Sor
    Yorum Ekle
  5. Swagtron T3 Gyroscope Replacement: adım 5, 2 resimden 1. Swagtron T3 Gyroscope Replacement: adım 5, 2 resimden 2.
    • Cut the plastic cable tie holding the cables together with utility scissors.
    • Disconnect the blue/green cable from the blue/white cable by pinching the connector clips and pulling the cables apart.
    FixBot'a Sor
    Yorum Ekle
  6. Swagtron T3 Gyroscope Replacement: adım 6, 1 resimden 1.
    • Gently lift the blue gyroscope off of the white plastic holder piece.
    • After reassembling the Swagtron with the new gyroscope, check to make sure your Swagtron is balancing properly.
    • If it is still unbalanced, repeat all steps in this guide with the gyroscope by the other wheel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Emily Richter
351 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G3
4 Üyeler
4 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where can one buy the new gyroscope?
Mike - Yanıt Paylaş
Where is the best place to buy the gyroscope for the T3?
I see Ebay sells complete kits with motherboards and all.
Are they compatible?
Mike - Yanıt Paylaş
where can I buy new gyroscope
roccovalletta - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 5,525
