Ana içeriğe geç
Swagtron T3 Wheel Replacement
Neye ihtiyacın var
  1. Swagtron T3 Wheel Replacement, Cover: adım 1, 2 resimden 1. Swagtron T3 Wheel Replacement, Cover: adım 1, 2 resimden 2.
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Wheel Replacement: adım 2, 3 resimden 1. Swagtron T3 Wheel Replacement: adım 2, 3 resimden 2. Swagtron T3 Wheel Replacement: adım 2, 3 resimden 3.
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
  3. Swagtron T3 Wheel Replacement, Wheel: adım 3, 1 resimden 1.
    • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
    • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
  4. Swagtron T3 Wheel Replacement: adım 4, 2 resimden 1. Swagtron T3 Wheel Replacement: adım 4, 2 resimden 2.
    • Pull the wheel off of its base.
    • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Klara Perkins
412 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G3, Forte Spring 2017 Cal Poly, Team S13-G3, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G3
4 Üyeler
4 adet Kılavuz yazıldı
3Kılavuz Yorumları
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - Yanıt
Can't the wheel off
Christopher Primo - Yanıt
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 4,413
