Ana içeriğe geç
Swann Doorphone Video Intercom Camera Replacement
Neye ihtiyacın var
  1. Swann Doorphone Video Intercom Camera Replacement, Camera: adım 1, 3 resimden 1. Swann Doorphone Video Intercom Camera Replacement, Camera: adım 1, 3 resimden 2. Swann Doorphone Video Intercom Camera Replacement, Camera: adım 1, 3 resimden 3.
    • Flip the outdoor camera over so that the underside is facing up.
    • Remove the back cover by grabbing the sides of the camera and pulling towards your body.
  2. Swann Doorphone Video Intercom Camera Replacement: adım 2, 2 resimden 1. Swann Doorphone Video Intercom Camera Replacement: adım 2, 2 resimden 2.
    • With the back cover of the outdoor camera off, press the first gray button, with blue wire underneath, down as shown in the picture.
    • While pressing the gray square button, remove the blue wire from the first opening under the button.
    • Be sure to remove the same color wire for the outdoor camera as was used for the indoor video intercom.
  3. Swann Doorphone Video Intercom Camera Replacement: adım 3, 3 resimden 1. Swann Doorphone Video Intercom Camera Replacement: adım 3, 3 resimden 2. Swann Doorphone Video Intercom Camera Replacement: adım 3, 3 resimden 3.
    • Remove the other wires using the same steps as the blue wire.
    • Using the JIS #0 screwdriver, remove the 2mm screws from the back plate.
    • Remove the back plate by pulling the plate away from the device.
  4. Swann Doorphone Video Intercom Camera Replacement: adım 4, 2 resimden 1. Swann Doorphone Video Intercom Camera Replacement: adım 4, 2 resimden 2.
    • Using the JIS #0 screwdriver, remove the 1mm screws from behind the camera.
  5. Swann Doorphone Video Intercom Camera Replacement: adım 5, 2 resimden 1. Swann Doorphone Video Intercom Camera Replacement: adım 5, 2 resimden 2.
    • Using one of the tweezers from the Precision Tweezers Set, gently place them around the wire connector attached to the camera.
    • Pull slowly in the direction of the cables until the connector is no longer attached.
  6. Swann Doorphone Video Intercom Camera Replacement: adım 6, 2 resimden 1. Swann Doorphone Video Intercom Camera Replacement: adım 6, 2 resimden 2.
    • Remove the camera from the device.
Sonuç
Emily Stenke
555 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G4, Eyestone Spring 2018 USF Tampa, Team S2-G4, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G4
4 Üyeler
5 adet Kılavuz yazıldı
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 650
